GE STACK WASHER DRYER
LEAKING?
3 replies to this topic
#1 dryerman45
dryerman45
    SAMANERA
  • Chief+ Appliantologist
  • 242 posts
  • Flavorite Brew:rootbeer
Posted 09 April 2013 - 10:15 AM
MASTER,
I have a GE  model # WSM2700TAWWB and the complaint is that it leaks at bottom left corner.This is near drain pump.I ran the unit 5 times filled at all levels and cannot find a leak.The only thing I saw was some dripping coming from the top around part that clips around tub.I dont know what that is called.Hoping there are some common leak problems that u guys have run into.Thanks
SAMANERA
#2 RussTech
RussTech
    Kohai
  • Chief Appliantologist
  • 309 posts
  • Flavorite Brew:Heineken
Posted 09 April 2013 - 08:02 PM
Are you talking about the tub cover, part # WH45X0150?
Just about any topload can get knocked a little too far to the front or the side when in spin with a heavy load. When it goes to fill again the water bounces off of the tub cover, splashing some outside the tub. Is your customer running heavy loads?
#3 Scottthewolf
Scottthewolf
    Senpai
  • 3,001 posts
Posted 09 April 2013 - 09:30 PM
Please move this to the laundry forum
Scott Wolf
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 April 2013 - 04:38 AM
:thumbsup:
