Sign in to follow this
Followers 0
AlaskaMatt
Fisher&Paykel fills too high
5 posts in this topic
I have a F&P DD603 integrated dishwasher drawer system. I'm getting a U1 fault on the bottom drawer.
The fault comes at 3:30 into the cycle. After I get the fault I measure the water in the tub and there was about 3-4 cm of water. I stopped the cycle on the top drawer at 3:30 into the cycle and there was 1-2 cm of water in the tub.
I've replaced the water inlet valve, blew the drain hose out to make sure there wasn't any blockages, swapped the rotor and controller with upper drawer...to no avail.
Any advice?
there is probably a blockage in the tube from the filter to the rotor
this is what i would check first
I checked that and it still gives me a U1fault. When I open the drawer there is water as high as the middle of the spray arm. When I put it into diagnostics to drain the water, it doesn't drain. I have to remove a few cups of water before it starts to drain.
Anything else you can think of?
I,appreciate your help.
If the unit drains properly and have already relpaced inlet valve, I would be suspicious of hall sensor (rps).  This unit doesn't have a float  to stop fill, so it relys on the info from motor readings to judge water level.  It fills, then cyces wash direction and takes reading.  Washarm has to be on and free to turn or will overfill and fault out.  If all of that is good check wiring to hall sensor, and replace if wiring is good.  Also gently grasp stator cage and make sure it snug, if windings are loose can cause same issue.  If that's the case would need new stator.
Good luck
I agree with btenpin to check rotor impeller and cage are tight on shaft.  Also check recess on motor where rotor rests for any defect that might cause binding.  I've seen motors swell the recess when overheating.  Make sure wash plate filter and debris filter are clear.  Check for any insect activity on or around both controllers.  Had a U3 fault on older model that had me chasing my tail.  Replaced water inlet valves and swapped controllers from top to bottom and still got the fault.  Turned out both controllers were bad. G'Day mate.
Followers 0
