certified tech group 51
Jenn-Air range....D-120
6 posts in this topic
Got an old J/A range...D-120....Complaint is slow to heat...Both bake and broil element operate when set to 'radiant bake'......takes about 10 minutes to reach  set temp. of 350 degs  ( actual temp is 390 ) and  then unit will settle at the set  temp with thermostat cycling.....Bake element is drawing 4 amps.   960 watts seems low but it is maintaining temps......Checked preheat against a new oven and  the new unit hit 350 degs in 8 minutes........do not have a wire diagram for the D-120...............  I do not think there is anything wrong with this unit, the range is in a weekend rental, it is just that most people do not get to use an almost antique................Rental agency whats me to tell the home owner it needs to be replaced, but in the last three years I have rebuilt almost every thing... ( new convection motor, new cartridges, new surface switches and new knobs ....  but not the T-stat, yet ).........rental agency would like to see newer appliances but they are not the one paying the $$$ to replace an old drop-in ................Any  old timer got in-site an old dog?????   .
I hear nothing unusual there, CTG...
10 minutes to preheat? Nothing wrong with that...sounds like they want want you to be the mouthpiece for getting the owner to upgrade...tell em to do their own dirty work.
Thanks,    Mr. K...............It's not every day you  see an old beast............When you check an element on a new unit,  the current draw is close to 10 amps. and with a bright orange glow.................This old one is only about 4 amps.   and a black/orange glow............Some folks like to keep Ol' Betsy going and those customers are in their 70's to 80's...............I have done quite a few new J/A installs and  the old units worked  O.K.....................The customer wanted a newer look....Those customers are in their 30's / 40's..............  The old ranges sat in the warehouse for a while cuz they were too nice to toss but after a while ( and a few cans of suds :gulp: )  they got recycled..............One old J/A can make two new ranges... :thumbsup:    .....
... and there's 240v going to the Range .. ?
and to the Element ?
not just 120v ?  :whistling:
  • If they do not like the 10 minute pre-heat cycle, wait till they get the new one with the hidden bake element that takes 20+! Lower wattage for smaller cavity units and this old girl has a much smaller cavity than the new units. I have a schematic if you do in fact need one, but it sounds like it's working as designed.
I agree.  Love this range!  Am gratified to see at least the thermostat is still available.
