bogreen
Kenmore Washer Model #417.44152400
8 posts in this topic
Hi,
Customer complaint was "no spin"
I ran the diagnostic test and per the results, main board not sensing that door was locked.
I replaced the main board and the problem persists.
Any ideas??
Bruce
... Kenmore 417.44152400
Kenmore ... this model made by Frigidaire
How's the Door Strike ?
http://www.repairclinic.com/referral.asp?R=154&N=1032664
during Spin, is the Door really locked ?
If so, then at that time,
un-plug the Washer from the Wall Outlet.
Can you then open the Door right away (bad)
OR only after a few minutes (good) ?
http://www.repairclinic.com/referral.asp?R=154&N=1531974
Door-or-Lid-Latch-Assembly-131763202-015
The strike looks good.
I tried the door while it should have been spinning. It was locked. Couldn't open it.
I don't quite get the test you suggested. How could the door be locked and disconnecting power then being able to open it
would indicate the switch was bad??
Shouldn't this have shown up in the diagnostics test?
Also, I didn't mention that during the diagnostics test, the machine did go into spin.
Besides the mechanical Door Lock,
there's a few Switches inside the Door Lock that need to be activated ..
Common problem on Frigidaires ..
Assembly could be opened and repaired ...
... Shouldn't this have shown up in the diagnostics test?
... Also, I didn't mention that during the diagnostics test, the machine did go into spin.
1) It's a Frigidaire  :whistling:
2) common symptom
  Diagnostics on these frigidaire washers will bypass the door lock.
The wax motor, (which is operated by a PTC heater alongside the wax cartridge/plunger assembly), is the part the physically locks the door latch shut when in spin.   Once you apply power to the wax motor it takes about 30-50 seconds for it to fully extend, it takes about 1-2 minutes to retract once power to the wax motor heater is removed, thus if you are able to open the door immediately after pulling the plug after the unit has sit in a spin cycle doing nothing for at least a minute or two then you know the wax motor locking mechanism in the door lock/switch assembly is bad.
If you put one of these machines into diagnostic cycle and it spins fine but won't spin in a normal cycle you can pretty much guarantee that the door lock/switch assembly is bad.
Thanks everyone. Excellent guidance.
The door lock/switch replaced handled the problem.
Bruce
