Learn how to be your own tech line…
desertfox40
Kenmore dryer 110.62952100
6 posts in this topic
Dryer does not stay on. Need help. Don't have diagram.
There are two relays in the console..P/N 3405281........swap the relays..........Make a difference???.......The other item could be the electronic control, If I remember, there should be 24 volts, from the board  to the relay......
Thanks. I'll check it out when I get a diagram.
... Drum Motor stops after a few minutes ?
... OR won't stay running unless the Start Button is held ?
Need more info.
