Frigidaire LGHS2667KE0 refrig SY CE error code & service manual request
roberto
Hello.  We are searching for a service manual for a Frigidaire LGHS2667KEO refrigerator.
According to the owner, the unit simply quit yesterday and the display began showing an SY CE error code. Any guidance would be appreciated.
Thanks
  • 3 months later...
That manual is oh so close... Do you have the manual for FGHB2844LF7 too?
I was able to clear customer's SY CE with 3 full resets but I have a feeling I'll be back.
