Maytag mvwc7eswwo No fill
3 replies to this topic
#1 prairiestr
prairiestr
    Kohai
  • Chief Appliantologist
  • 271 posts
  • Flavorite Brew:Jack
Posted 18 April 2013 - 10:38 AM
No fill, no agitate, spins and timer advances in spin cycle, voltage to ATC control when timer in fill but no voltage to valves, checked pressure hose seems clear.
Bad ATC control?
#2 bayouboy
bayouboy
    Sōhei
  • 146 posts
  • Flavorite Brew:Abita Beer Purple Haze
Posted 18 April 2013 - 11:20 AM
Sounds like it, I have replaced a couple of these with the same issue.
http://www.repaircli...0248240/1549115
"If switch fails make sure drain hose is up at least 42 inches from the finished floor and is discharging into an open stand pipe or laundry tub to prevent water from siphoning that can damaging switch."
Off repair clinic site, I didn't know that!
#3 PDuff
PDuff
  • 2,045 posts
Posted 25 April 2013 - 02:45 PM
Bad ATC p/n W10248240.  Not a bad truck stock part but kinda expensive.  Had those washers right out of box with bad ATC's.  At least it's a direct drive.
#4 suampman
suampman
    Kohai
  • 307 posts
  • Flavorite Brew:redbridge
Posted 25 April 2013 - 05:10 PM
Reseat all plugs in control panel before you drop 90 bucks.
