Sign in to follow this
Followers 0
Raynormensk
LG fridge ice clumping in bin. LFX31925ST/02
4 posts in this topic
Lg had me replace the board and the back frezzer panel to stop the ice from clumping in the bin, nothing obvious like air leaks. Anyone seen this before? Any ideas would be helpful.
Air Leak> Is the duct assembly tight?
Temp Problem/Infiltration> Compartment below 10 degrees F?
Premature Harvest> At least 120 minutes?
Software Programing> Water overfilling?
I've seen a lot of the icing fans(fan that supplies air to ice compartment) stop or get noisy due to ice build up, lg has supposedly redesigned evap cover and increased fan speed to help with this issue
Ended up turning the temp colder in the frezzer and turning on quick ice. I had already replaced the evap cover and board as per LG.
Followers 0
