Sign in to follow this
Followers 0
nonappliancerepairguy
Maytag MAV72608WW shaking down the house
10 posts in this topic
Washer is wrecking my house one shake at a time. Started with no spin at all. I found the pulley on the underside of the cabinet had lost retaining clip and had dropped enough to disengage. I got a new clip put it back together and it worked until spin cyle. On spin cycle, with load or without. Same sturdy level floor as the last 5 years. Feet on floor adjusted to level. It shakes like it wants to walk out the door and down the street. I pulled the front cover off and the springs are in good shape, everything looks like it should......until spin. It turns smooth until a criticle moment and then it wobbles and bangs. There is a small amount of white shavings at the base of the cabinet. Snubber?
If snubber what else should I replace while I am at it?
Anyone?
After further review It has been disclosed to me that the washer, at the time of no spin, was packed to the rim with towels. "there may have been a few too many towels, maybe more then a few too many"
Snubber replacement. Loads of fun for everyone. Tip : if you don't have a spring removal tool, use a pair of channel locks to remove tbe springs. However, I find the following method easier... get yourself 6 standard size metal electrical outlet boxes. When it comes time to remove the springs, stretch the spring a bit by moving the tub slightly in the opposite direction. Then wedge the open end of one of the boxes lengthwise on the spring. Like magic, the box will keep the spring stretched for easy removal and re-installation. Repeat for all 6 (or however many you model has) springs.
After running, the tub assembly/springs  are rotated clockwise so the springs lean in the same direction. The tub can easily rotated by hand so the springs are verticle. Not sure if that is normal. The tub can be moved side to side, front to back with ease. There are a few fine white shavings under the tub sitting on the center of the cabinet bottom.
The retaining clip that was missing was the one  on the right side of the second part image that was attached.
fine white shavings are usually from the snubber ring. Check your springs as well
What am I checking when I check the springs? They are all there and appear to be fine. What is the next step O wise ones?
Dear appliance repair gods:
Replaced said snubber ring. Put it back together (no extra pieces laying around this time). Ran it empty and it was a shaking, nothing like before though. Came home from work today, listening to it pur ........ until the spin cycle. banging, crashing, shaking, cats running for shelter, evil look from wife, kids laughing. Clearly not the snubber ring.
There was very little wear on the old snubber ring. Springs all tight and happy. nothing bent, no oily residue, damaged, askew, amuck or out of place.
The drum spins smoothly until "take off" and then it wobbles and bangs. Is it possible that gunk has it off balance. My wife does call me pig pen. I got uncommonly dirty cloths.
Please Help!
Followers 0
