Sign in to follow this
Followers 0
EpGolfer
Bosch SHY56A06UC/23 Wont Run
3 posts in this topic
I have a Bosch SHY56A06UC/23 that when I turn the unit on the drain pump just constantly runs, and water will not come out of the sprayer arms. When I came home last week the dishwasher had water standing in the bottom so I have replaced the drain pump thinking that is the problem but now when I turn the unit on you can just hear the drain pump running but water will not spray at all. I have cycled the breakers any other ideas of what might be causing this issue? Thanks!
There is a float in the pan under the dishwasher, kicks the drain pump on and will not allow any other function until the float is reset. You'll have to pull the dishwasher out and determine why the float switch engaged -- in other words, find the leak.
If water is found in base and drain hose is not damaged, could be leaking from circulating motor. Circulating motor p/n 437345 or just replace seal/impeller kit p/n 167085.
Followers 0
