elmonducky
Frigidaire Double oven PLEB30T8CCB No bake either oven
10 posts in this topic
No bake either oven, broiler comes on to assist in preheat but no bake.  Elements check good.  Not familiar with this model could not figure out how to remove oven to check thermostat.  Any suggestions??
... No bake either oven, broiler comes on to assist in preheat but no bake.
... Elements check good.
sounds like a bad BAKE Relay on each Relay Board,
OR a bad Oven Controller,
not sending power to the Relay Coils
http://appliantology.org/files/file/769-frigidaire-oven-pleb30t8ccb-parts-list-wiring-diagram/
http://www.repairclinic.com/Frigidaire-Range-Stove-Oven-Model-PLEB30T8CCB-ID-626372-Circuit-Board-Timer-Parts
1 person likes this
Hmmm,  would like to be able to remove this from wall to verify.  Looks like side trim needs to be removed to access screws that mount wall oven to cabinet.  Removed all visible screws but still not able to remove.  What am I missing??
Thanks, im wondering if the thermal breakers are open due to perhaps a cooling fan failure?  Looking for a common denominator.  But it looks like if the thermals are open the broiler wouldn't work either.  The control board seems to be the only component in common but the broilers heat up when put in bake so hard to believe that would be the cause.
did these problems happen at the same time ?
OR months or years apart ?
Were the Bake Elements possibly bad, (causing Relay failure)
and someone else replaced them ?
Elements have never been replaced to my knowldge.  The customer seemed to indicate that the top oven went out before the bottom one.
Follow up, turns out both upper and lower relay boards were bad
Wow, very unusual for two boards to blow at once.  Wonder if there was a power surge that took 'em both out.  Good job on the fix and thanks for letting us know!
