The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
Sign in to follow this
Followers 0
prairiestr
GE Frig PFSF5NJWA Not cooling
7 posts in this topic
Compressor not running, or even trying.
Condensor fan is running constantly, Evap fan also running.
Can't find a tech sheet anywhere on this machine.
Help please!
Most likely going to be a main board or the compressor inverter board. There will be a small plug with a red and white wire running from the main board to the inverter board. Check this plug for dc voltage. If no voltage main board is bad. There are few other tests to do but check that first. I am going to suspect the inverter board is bad.
Thanks Applianceman,
Any idea where the tech sheet might be hiding?
Not behind the front grill? Thats where it should be. I have more specifics on the voltages and wiring at my shop. I will try to get you more info. Maybe even a manual.
Any info would be great. Tech sheet not behind grill or in compressor compartment.
Thanks Durham,
This will be a big help.
Followers 0
