Sign in to follow this
Followers 0
bogreen
Kitchenaide Refrigerator Model #KSCS25INSS00
3 posts in this topic
Hi,
This unit is not making ice.
I opened the freezer door and checked the on/off switch. It was ON.
The sensor was blinking red. I held the flap in so the beam could complete
the circuit when it should turn to a steady red light. But no, it stayed blinking.
I think that means the two components are not communicating to each other.
Does this seem right?
Bruce
Also check your module.  Inspect the cam dog ears that hold the drive gear in place.  If one of the tabs are broken the drive gear will separate from the module and break the contacts behind the gear.  You might even find the broken tab rattling around in the module cover when you remove it.  If so just replace the module or the icemaker as an assembly.
Followers 0
