Patricio
Frigidaire SxS refrigerator FRS26KW3AW4
5 posts in this topic
Have a refrigerator that won't defrost,  Heater has good resistance, defrost limit is culprit, no continuity.  Want to check ADC, how do I initiate defrost  cycle?    Manual controls, 2 thermostats.
NOTE: This product comes equipped with an Electronic Defrost Control.
To initiate defrost, depress the fresh food light switch 5 times in 6 seconds
(light bulb must be working).
To terminate defrost, depress the fresh food light switch 5 times in 6 seconds.
So if it does not initiate?   & I do not get 120v out of E1 Bad Control board?     Also looking at replacement board, looks like board in plastic box, original not.  Also new harness must be wired in.   Mostly positive problem is in limit, encased in ice & no continuity.
... I do not get 120v out of E1 Bad Control board?
... board in plastic box, original not.  Also new harness must be wired in.
... Mostly positive problem is in limit ... no continuity.
1) assuming Wall Outlet polarity is correct
2) seems they had a problem with the original design
3) may not go into Defrost if it "thinks" the Limit is too warm
did you jumper the Limit before trying "forced Defrost" ? :whistling:
http://appliantology.org/files/file/790-frigidaire-fridge-frs26kw3aw4-wiring-diagram/
http://www.repairclinic.com/referral.asp?R=154&N=1614983
Defrost-Control-Board-5303918476-0117628
I will now I know how to initiate defrost.   Let you know outcome this evening.
