KitchenAid Washer Water Temp Mixer
Started by Pelorus, May 05 2005 09:47 AM
3 replies to this topic
#1
Posted 05 May 2005 - 09:47 AM
The water temperature selections (wash and rinse combos) for my KitchenAid washer (Model KAWS700G) is not functioning----- Hot/Cold on the dial setting is actually Cold/Hot, Cold/Cold is actually Hot/Hot, Warm/Cold is actually Warm/Hot.
Is the problem likely on the water temperature control board (circuit board) or is thare a mixing valve in the washer that has gone bad or ----- something else?
#2
Posted 05 May 2005 - 10:16 AM
I would see if the fill hoses are reversed to the washer from the water faucets. Or the faucets in the home are backwards. Pegi
Buy your parts here!
Read More
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 11 May 2005 - 10:56 AM
Pegi:
You are the Master-- thank you!
As the source of the problem (reversing the connections) I uttered a Homer Simpson "D'oh."
Thanks again.
Thanks again.
#4
Posted 11 May 2005 - 11:03 AM
Hahahaha......Thanks, glad I could help, as was the only reason for this problem. Appreciate your reply. Pegi
Read More
