Sign in to follow this
Followers 0
bimbbobway
microwave making a humming noise for no apparent reason.
4 posts in this topic
Model MH3184XPS2 Ser TRS4019737. I have a microwave that is humming for no apparent reason. The customer states that the microwave hums all the time even when not in use. She says as soon as you plug it in it will home until you unplug it. While plugged in and making a humming noise it will function normal the lights will come on and off it will heat the fan will work. I tested all the obvious stuff door switches, magnetron, Diode, turntable motor all seemed fine. While I was there it would not make the humming noise. Has anyone ever seen anything like this before? I might have a crazy homeowner.
More than likely one of the relays is going bad on the electronic control board. Sounds like you need to replace the electronic control board.
 I have a microwave that is humming for no apparent reason....
sorry, I couldn't resist.    Yeah...what they said.
Followers 0
