Whirlpool Dishwasher Model# WDT790SAYB, Fills and Drains OK, Doesn't Run
22 replies to this topic
#21 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 709 posts
  • Flavorite Brew:Coffee
Posted 29 May 2013 - 09:05 PM
Nice job.  This motor/sump assembly is easily changed without pulling the DW or even disconnecting the power.  Disconnect and remove the drain motor from the front.  Reach in and flip the 3 lock tabs.  Push the pump/sump up into the tub.  Then disconnect the wires from inside the dishwasher.  (Careful of the sharp edges.) Reassemble the same way.  About 20 mins total.  WP really did make these pretty easy to service.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#22 reeferman
reeferman
    Sōhei
  • Master Appliantologist
  • 211 posts
  • Flavorite Brew:Pure water
Posted 09 October 2014 - 06:44 PM
This is a great new source for leaks! You'll have to replace the sump (only way to replace the seal), diverter motor, and the now corroded wire harness...
Does anyone know if a repair wire harness exists for this, or do you really have to replace the entire harness: W10496093? Chat, I've seen this before during an inspection a couple years ago and just saw another one yesterday.
ross
#23 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,503 posts
  • Flavorite Brew:What's on tap?
Posted 10 October 2014 - 06:13 AM
You have to order the harness, but I've cut and spliced just the wires to the diverter motor. I look for this everytime I work on a GWS now, saves me a recall and the customer possible water damage.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
