Maytag/Whirlpool Bottom Freezer Defrost Issue: JAZZ Board?
35 replies to this topic
#21 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,376 posts
Posted 09 May 2013 - 08:44 PM
Nice markup, Brother Strath.  It's not necessary to pull down #2 in your drawing.  Just remove the light shield and the tabs to drop the control board housing are right there in back.  I use my Mac extendible mirror and a straight-blade screwdriver to release those clips and drop the housing.  Two unsnaps and done.  R&R the control board, button that baby up, reprogram it, and collect that hot, wet, stinky cash.   :dazzler:
#22 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 718 posts
  • Flavorite Brew:Coffee
Posted 09 May 2013 - 08:52 PM
I've done both ways - I've not tried your way with a mirror though.  This is a 5 min job for me ... not sure if I need to make it any faster.  lol.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#23 AlexM
AlexM
    Kohai
  • Chief Appliantologist
  • 378 posts
  • Flavorite Brew:Root Beer
Posted 09 May 2013 - 09:23 PM
This web site is outstanding, and Kohai, your drawings are awesome.  I successfully got the board replaced, and didn't look at this post in tell just now, but I pretty much pulled everything down and amazing that I didn't break any tabs, its crazy.  this post will help newbees like me stress a little less.  Luckly for me, the customer didn't watch me tugging and pulling.  thanks again!
#24 Samurai Appliance Repair Man
    Shōgun
  • 30,376 posts
Posted 10 May 2013 - 07:21 AM
Nice pix!
#25 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 718 posts
Posted 10 May 2013 - 10:36 AM
Here is the other way that Samurai was saying to get at the Jazz board.
#26 DurhamAppliance
    Sho' Nuff Chozin
  • 5,618 posts
Posted 10 May 2013 - 09:04 PM
that's the way i do it. Have become pretty proficient at it but always looking for better methods.
www.DurhamApplianceThrift.com
#27 Samurai Appliance Repair Man
    Shōgun
  • 30,376 posts
Posted 11 May 2013 - 01:24 AM
Yep, that's how I do it.  The less I have to take apart means less opportunities to break stuff!
#28 DurhamAppliance
    Sho' Nuff Chozin
  • 5,618 posts
Posted 11 May 2013 - 11:39 AM
Your markup is a whole lot better than my pathetic drawing !
#29 AlexM
AlexM
    Kohai
  • 378 posts
Posted 11 May 2013 - 01:06 PM
...from now on, this is the only diagram I need to fix everything! Thanks!
#30 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 May 2013 - 02:22 PM
#31 AlexM
AlexM
    Kohai
  • 378 posts
Posted 13 May 2013 - 12:26 PM
HELP!  MY CUSTOMER JUST CALLED BACK...
They say that the control panel/light cover, (at JAZZ board)  is extremely hot.  He can open the fridge door and hold down the door switch and the light bulbs turn off, then on when open.
It is so hot that it warming up the FF section.
I did replace two burned out light bulbs with two FSP 8009 light bulbs, the original two were burned out.
Any ideas?
#32 PDuff
PDuff
  • 2,045 posts
Posted 13 May 2013 - 12:47 PM
Sounds like the door switch isn't being actuated by the door.  Check for loose light panel.  Might need to adjust door.  There's a shim available for the side by sides but not sure if it'll work for this one.
#33 DurhamAppliance
    Sho' Nuff Chozin
  • 5,618 posts
Posted 13 May 2013 - 01:04 PM
this is when a killowatt meter comes in handy... plug it in and you can quickly determine by amp draw if the light is staying on when doors are closed.
Make sure the control housing is seated properly... not sure if it will affect light switch contact on this model but it takes a lot of force sometimes to snap it back in place... look for space between housing and ceiling (on the left and/or right side) .. if you see it, then the housing is not seated properly..
yeah for sxs I usually solve the problem by adding a washer on the bottom hinge pin if top hinge adjustment doesn't solve problem.
#34 RegUS_PatOff
  • 33,588 posts
Posted 13 May 2013 - 01:12 PM
http://www.repaircli...r/P4400/1012487
brochure
http://p3internation...hures/P4400.pdf
user manual
http://p3internation...4400_manual.pdf
#35 AlexM
AlexM
    Kohai
  • 378 posts
Posted 13 May 2013 - 01:34 PM
Thanks, I'm on it...I will report back.
#36 DurhamAppliance
    Sho' Nuff Chozin
  • 5,618 posts
Posted 13 May 2013 - 01:41 PM
brochure
user manual
Man, I love this thing. It's another one of my all time favorite tools. During basic electricity class at Asti, they were pumping it up, showing how you can use it on all kinds of appliances including microwaves and dryers (motor/timer tests using a 120v cord adapter). So while techs were gooing "oooh and aaaaahh" just as they did when later classes were discussing benefits of using a steamer, I was ahead of the game. Because of Appliantology, I already was using them and the benefits of using them was old news! Yeah yeah, I know you can use a clamp meter and line splitter... but coolness counts for something, doesn't it?
