jb8103
Kenmore/Amana Bottom Mount 596.65939401
8 posts in this topic
Beer side not cooling. Freezer is A-OK. I have the service manual downloaded from pot luck. (Amana Bottom-Mount Refrigerators Service Manual RS1200000)
This is intermittent. Customer couldn't recall how they cleared it up last time except for "doing something with the temp controls".
What's the most common problem?
Edited by jb8103
You're probably going to find the evaporator coil in the freezer choked in with frost, in which case, the problem is almost always the infamous Jazz Control Board.
There's a tech sheet in the toe grill that tells how to put the board in diagnostic mode for various tests.  But the most common failures with this board are 1) failing to initiate defrost and 2) keeping compressor running during defrost.  Both result in a frosted up evaporator coil.
Put the unit into forced defrost.  If the defrost heater fires up, that means the defrost heater and limiter are good.  Then go ahead and replace the Jazz Board.
Here's my video showing how to do the diagnostic dance:
It is indeed a JAZZ PCB, Samurai.
But if the evap is frosted would not the freezer side be affected also?
Eventually, yes, and it may already be affected.  Temperature should be 0F in the freezer.  If the actual temp is 15F or more, then it's already affected.  You can't tell the difference between 0F and 15F by feel-- you have to measure it.
Of course, the best thing to do is to get eyeballs on the evaporator coil.   :smokin:
Eyeballs it is. Back to the customer site.
Domo!
Freezer temp 17 degrees, thick frost coating the evap cover. We await resolution of a landlord/tenant dispute as to who pays the bill before proceeding.
I suspected the damper, but pending the forced-defrost test, looks like you nailed it. Huzzah!
Meanwhile the beer side has started cooling again. I informed the tenants a goofy board will misbehave like this, but sooner or later they will wake up to a flood of melted goodies and bins full of spoiled food. And who pays for that?
Oh joy... I'm being sarcastic.
First time I had to yank a Jazz board I ended up calling a buddy in Washington DC for advice because I couldn't figure out how to crack into that tuna can without breaking it into pieces. He walked me through it.
If you don't know how to get that cover off, call someone and have them walk you through it on the phone... seriously. It requires you to shove a screwdriver in there with about ten times the amount of force you'd think was necessary. If you do it in the right place, the cover comes off.
If you do it in the wrong place, things can get expensive and time consuming.
