GE GTWN4950L0WS washer - chattering noise under tub
5 replies to this topic
#1 miamihoosier
miamihoosier
    Ikkō-ikki
  • Chief Appliantologist
  • 36 posts
  • Flavorite Brew:Andechs Dopplebock Dunkle
Posted 05 May 2013 - 07:24 PM
I have a GE GTWN4950L0WS washing machine making a chattering noise under the tub.  It fills, spins and drains fine.  I guess some ears or cogs not cooperating in the transmission?  Anyway, I'm stuck in removing the 1 11/16 nut (which has loosen and a clockwise arrow on it). Attached File  GE GTWN4950L0WS.jpg   86.34KB   12 downloads   I chewed it up a little with a pipe wrench.  Shouldn't this be easy??? I have an 1 11/16 deep-well socket on it now, but I can not break it free???  Am I being an idiot? Am I missing something or just a weakling?  I assume I need a new clutch ( Clutch WH38X10017, shaft and mode shifter assembly)  Any help would be appreciated.  Thanks!
Edited by miamihoosier, 05 May 2013 - 07:39 PM.
    Shōgun
  • Master Samurai Tech
  • 30,022 posts
Posted 06 May 2013 - 04:39 AM
Very easy... if you use the correct tool:  Tub Nut Wrench.
Video on removing the tub nut.
#3 miamihoosier
miamihoosier
    Ikkō-ikki
  • 36 posts
Posted 06 May 2013 - 05:53 AM
Thanks!  I know the wrenches are out there, but wouldn't you think a deep-well socket would work just as good?  Have you ever had one that was frozen?  Maybe I'll borrow one from a friend as an experiment...
    Shōgun
  • 30,022 posts
Posted 06 May 2013 - 05:55 AM
Experience is the best teacher.  What does yours tell you?
#5 miamihoosier
miamihoosier
    Ikkō-ikki
  • 36 posts
Posted 06 May 2013 - 07:36 AM
Just chalked up another lesson...  Finally got it apart.  Transmission fine.  Ok, I'm an idiot.  It was such an odd noise, like metal grating on plastic. I couldn't pin it down earlier.  Re-assembled.  Thought it was somehow a bad plastic coupler, even though it looked fine.  Tried it again re-assembled.  Same noise.  Looked much harder to pin it down.  So simple.  Something in the drain hose against the pump slightly.  Bra wire!!!  Attached File  Wire.jpg   24.12KB   1 downloads How could it get there???  Who knows.  Removed.  Works great.
#6 SANTA
SANTA
    Senpai
  • PipPipPipPip
  • 816 posts
Posted 06 May 2013 - 10:37 AM
Those bras are nothing but trouble and frustration but sometimes needed.  2143.jpg
