jambatt
GE WJRE5500GOWW Washer
9 posts in this topic
Anyone know the amp rating on the thermal fuse in the harness?? Any reason it couldn' t be replaced with an ATC or ATO fuse of the same rating?
I thought GE wanted the fuse removed? They have a "kit"... a piece of wire and 2 crimp connectors that they send with new motor/inverter.
  Original fuse is 10 amp. Service bulletin says;
New variable speed inverter motors no longer
require the in-line fuse. When replacing an
older Hydrowave inverter motor with the new
inverter motor, the in-line fuse must be
removed from the washer harness. Failure to
remove this fuse link will cause the fuse link to
fail due to the higher inrush current of the new
motor design.
Replacement motors will include a jumper wire
and 2 wire splices to remove the in-line fuse.
do you have a number of that service bulletin ?
Training Bulletin TB 09-10
One time I found that fuse open and I jumped it out. The results were electrifying to say the least.
Well, don't say the least, tell us some mo'!
