Washer Dryer Combo Error Code ER13, Haier, Summit, Ariston
31 replies to this topic
#21 Budget Appliance Repair
  • 4,930 posts
Posted 14 May 2013 - 08:51 AM
A thermal link should be closed, it is a one time thermal safety device, too much current/heat and it opens and has to be replaced.
Again, I don't know if that is in-fact the thermal link that is being talked about - just using logic of seeing that it comes with the t-stat kit and the problems the ER13 code mentioned about the thermal link.
William Burk (Willie)
Eureka, CA 95501
#22 drkwoods
drkwoods
  • 19 posts
  • Flavorite Brew:Pliny the Elder
Posted 14 May 2013 - 07:30 PM
Thermal link (sheathed wire off thermostat) is closed and seems normal. No burn or heat marks. I ran the dryer and felt the motor spin and could hear air flow. I saw someone else mention lint getting stuck in this plenum assembly below the thermostat but I can't tell yet.
Dark Woods Brew
"If you dont see it, thats not it"
#23 PDuff
PDuff
  • 2,017 posts
Posted 14 May 2013 - 08:13 PM
How about fan operation by the t-stat and thermal link?  If fan is working we might be looking at a full on lobotomy.
#24 drkwoods
drkwoods
  • 19 posts
Posted 14 May 2013 - 11:39 PM
Yea the fan runs. I felt the back side of the shaft spinning with the dryer mode on
Dark Woods Brew
#25 drkwoods
drkwoods
  • 19 posts
Posted 22 May 2013 - 07:53 AM
Well Ive tried everything and it all tests out ok. The thermostat, thermal link (fuseable) , the fan motor, the condensing tank (did have quite a bit of lint but not enough to stop drying), the Heater is fine..
I get ER13 code about 15 min into a dry cycle.. The wash cycles are all fine, no problem.  If I run the touch-up dry cycle it will error code in 15 min, I feel heat and there is decent fan and air flow, the clothes are even beginning to dry. Ive tried running the quick cycle again right after the Error code and it has made it through to complete a couple of times and didnt error or stop. So Im guessing I'll replace the pcb?  Can i test it? is there more than one?
Dark Woods Brew
#26 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 May 2013 - 10:51 AM
... but unit does heat up and quits 5 min into heating with the code 13..
Heater works, but PCB thinks there's something wrong with the Heater
does sound like a bad PCB
Have you tested to make sure the Heater isn't partially shorted to chassis / ground ?
#27 drkwoods
drkwoods
  • 19 posts
Posted 25 May 2013 - 09:30 AM
yea the heater is fine.. nice and hot and runs the entire heat cycle until the error code at the 15min mark every single time
Dark Woods Brew
#28 RegUS_PatOff
  • 33,588 posts
Posted 25 May 2013 - 10:32 AM
that would cause it to be ON, when it shouldn't be
If you set the Dryer Cycle for no-heat / air fluff,
is there any heat ?
#29 drkwoods
drkwoods
  • 19 posts
Posted 25 May 2013 - 11:51 AM
It doesn't have an air/fluff mode. Not sure how to test heater for intermittant short?
Dark Woods Brew
#30 drkwoods
drkwoods
  • 19 posts
Posted 19 June 2013 - 02:49 PM
This thing has two PCB's I think...? Which one would I replace?  wd-5210-11   or    wd-5210-12 ?
Dark Woods Brew
#31 drkwoods
drkwoods
  • 19 posts
Posted 28 June 2013 - 12:18 PM
Finally Fixed!!  Swapped out the PCB WD-5210-12 and we have full cycles now.. Also pulled quite a bit of Lint stuck in the evaporation tank..   thanxx all for the help!
Dark Woods Brew
#32 tonytech81
tonytech81
    Ikkō-ikki
  • Appliantologist
  • 50 posts
  • Flavorite Brew:Bud Lime @ cold Tea
Posted 24 January 2014 - 09:35 PM
Great find wow wow thanks
3 user(s) are reading this topic
0 members, 3 guests, 0 anonymous users
