Kenmore 70 series washer
Started by repdog, May 05 2005 10:14 AM
3 replies to this topic
#1
Posted 05 May 2005 - 10:14 AM
My Kenmore 70 series washer just stopped after the wash cycle. It is at the point where it usually starts to drain before the spin cycle.
I tried moving it to the "perma-press" side of the dial, but still nothing. I also tried to get it to just rinse & spin, but no good. It is happy to wash again though.
Thanks!
Thanks!
#2
Posted 05 May 2005 - 10:21 AM
Without a model number we do not know what style this washer is. 70 series just tells us what line it is as far as bell and whistles. If it is less than 20 years old it sounds like you have broken your lid switch, cutting the power to the motor for drain and spin. If it is an older belt driven washer this will not apply. Pegi
Buy your parts here!
Read More
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#3
Posted 05 May 2005 - 10:30 AM
YOU NAILED IT!!!
I just by-passed the switch and it is running through all cycles!!
I am trying to hold off for a couple of months before I buy a stackable set and this really helped.
Thanks!!
Thanks!!
#4
Posted 05 May 2005 - 10:45 AM
You are very welcome....Thank you for posting the results, we really appreciate knowing how these problems turn out and it helps others. ;) Pegi
Read More
