Sign in to follow this
Followers 0
frunch
Whirlpool GI5SVAXVL00 Refrigerator Freezing Food in Crisper Bins
4 posts in this topic
I have a customer with a Whirlpool refrigerator that has been freezing fruits and vegetables in the crisper bins. Model #GI5SVAXVL00, this is a high-end model with the french doors and bottom freezer drawer. It also has the ice maker located in the upper-left area of the refrigerator section. They've played with the crisper bin humidity controls to no avail (turned all the way up, all the way down, doesn't seem to make any difference). I ran the diagnostic tests (through the keypad on the front of the left refrigerator door) for all of the refrigerator's components and nothing appeared to be broken or working improperly. The freezer is working fine, and the refrigerator section is cooling properly. I'm stumped as to what this may be! In my google searches for any other answers or advice, I came across a kit that looks like a roll of weather stripping that's called a 'Water Tank Freeze Kit'--but I don't know if installing that kit would have any effect on the temperature in the crisper bins. Any suggestions what to look for, or advice as to how I may resolve this issue?
Thanks!
Trevor
After consulting a fellow Appliantologist, I found out about this kit: http://www.repairclinic.com/PartDetail/Cover/W10295078/1875416
It appears to be an upgraded ice bin cover that makes a better seal for the ice bin assembly, preventing cold air from escaping from the ice bin section in the refrigerator. I'll have to consult the customer to see if they'd like me to proceed with the repair, and if they do have me order and fix it, I'll update my post with results.
In the meantime, has anyone out there installed one of these for a similar issue?
Trevor
I've never had the pleasure. Looking forward to your extensive photo essay.
Well, after adjusting the temperature from 38 to 41 degrees in the refrig section, the problem is resolved...for now. If the problem should rear it's ugly head again, I may get the opportunity to install the kit I linked to above. In the case that I do, I will certainly take photos and document the process for further reference.
Trevor
Followers 0
