GE Dryer, DDE5100RALWH Heating element.
9 replies to this topic
#1 blockisle9
blockisle9
    Ikkō-ikki
  • 22 posts
Posted 16 May 2013 - 03:37 PM
I'm trying to find out the part number for the heater coil for a dryer model number DDE5100RALWH.
When I try and search the only thing I can find is for model number DDE5100RALWW.
Are they the same?
I've replaced the elements on other dryers, however this one seems a bit more involved and its quite a bit more money. (That is if the WH and the WW are the same)
Any input would be helpful.
Thank you very muck
    Shōgun
  • Master Samurai Tech
  • 30,903 posts
Posted 16 May 2013 - 03:42 PM
Two ways to go on this one: the cheap hard way or the easy more expensive way.
Here's the cheap, hard way using the heating element restring kit:  http://www.repaircli...er=DDE5100RALWW
Here's the plug n' chug easy way using the pre-strung heat can:  http://www.repaircli...er=DDE5100RALWW
Heating-Element-Assembly-WE11X103-008421
It's good to do it with the re-string kit once because then you realize the value, economy, and reliability of the pre-string can.
And, yes, they are the same heating elements for both models.
#3 blockisle9
blockisle9
    Ikkō-ikki
  • 22 posts
Posted 16 May 2013 - 05:08 PM
Thank you very much!
I will go with the easer option..
The last one I did for another friend was very easy, right on the top. This sounds more involved, how much has to disassembled to get to it?
I haven't checked the thermostat or the high safty yet, I just assumed it was the coil but I will check them first.
Are the easy to get to, to check them? Were can I located them on the dryer.
Sorry for all the questions??
Thanks again
    Shōgun
  • 30,903 posts
Posted 16 May 2013 - 05:12 PM
The first part of this video shows basic teardown for this dryer.  Piece of pie, tovarish!
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 16 May 2013 - 06:07 PM
... I haven't checked the thermostat or the high safty yet, I just assumed it was the coil
have you checked the voltages at the Dryer Cord Terminal Strip ?
#6 blockisle9
blockisle9
    Ikkō-ikki
  • 22 posts
Posted 16 May 2013 - 08:30 PM
Yes I have both legs hot, 220 volts
#7 blockisle9
blockisle9
    Ikkō-ikki
  • 22 posts
Posted 16 May 2013 - 08:39 PM
Yikes! That is way more than the last one I did..
I didn't see the locations of the t-stat or safety?
#8 Scottthewolf
Scottthewolf
    Senpai
  • 2,975 posts
Posted 16 May 2013 - 08:47 PM
Can we PLEASE move this to the laundry forum?
Scott Wolf
    Shōgun
  • 30,903 posts
Posted 16 May 2013 - 08:50 PM
Huh? What?
#10 RegUS_PatOff
  • 33,588 posts
Posted 16 May 2013 - 08:55 PM
... but... but.. but... I have the Dryer in my Kitchen ... :wink:
... I didn't see the locations of the t-stat or safety?
video @ 2:20 there's (2) or (3) on the right side of the Heater
