Washer shaking MAV7200AWQ
11 replies to this topic
#1 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 17 May 2013 - 07:37 PM
Washer shaking!!!! Changed snubber and suspension springs and still the same!!! WTF
#2 Applianceman97
Applianceman97
    "Hollywood"
  • 2,595 posts
Posted 17 May 2013 - 11:16 PM
Soft floor causing machine to shake?
#3 KCTBURY
KCTBURY
    www.ieappliance.com
  • Chief Appliantologist
  • 109 posts
  • Flavorite Brew:Coke
Posted 18 May 2013 - 03:27 AM
Maybe take the brake spring out and see if it still shakes.
#4 mark mac
mark mac
    Sōhei
  • Appliantologist
  • 238 posts
Posted 18 May 2013 - 07:16 PM
Could have a bad base have replaced quite a few
#5 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 19 May 2013 - 09:01 PM
It has a very solid floor! The big spring that's there when u take pulley ect apart when changing snubber??? And how do u know if base is bad???
I was curious if stabilizer bar could play a role in shaking???
#6 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 28 May 2013 - 06:05 PM
Anyone???
Any thoughts appliance repair man?
    Shōgun
  • Master Samurai Tech
  • 30,708 posts
Posted 28 May 2013 - 09:39 PM
Sounds like all you're left with is replacing the tub support.  Some poop:
Tech bulletin:  http://appliantology...nical-bulletin/
Tub support part link:  http://www.repaircli...21001518/436844
#8 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 28 May 2013 - 09:43 PM
    Shōgun
  • 30,708 posts
Posted 28 May 2013 - 09:48 PM
If you've already changed the snubber and suspension springs, and the floor is solid, washer weight is equally distributed among the four footings, that's all you're left with.  See the tech bulletin I posted for more details.
Define what you're calling the stabilizer bar.
#10 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 28 May 2013 - 09:50 PM
So could stabilizer bar play a role in violent shaking??? Tub doesn't bang against sides it just shakes!!! Can I run washer without brake spring in??? And is the spring the big one u see when changing snubber???
#11 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
Posted 28 May 2013 - 09:57 PM
Rear feet, self leveling bar on rear bottom of base
#12 JJ Surfer
JJ Surfer
    Sōhei
  • Appliantologist
  • 154 posts
  • Flavorite Brew:Sierra Nevada pale ale
Posted 30 May 2013 - 04:07 AM
Don't run washer without brake spring, it will spin in agitate and leak! Stabilizer bar just sets rear feet, as mentioned in earlier posts if all four feet are solid on the floor then that bar is ok. If you tilt the washer forward lifting the rear off the floor do the rear feet extend down? This is how you reset the rear feet. When it shakes do all four feet stay on the floor? With the front off and the unit spinning with a load watch machine base for signs of flexing, I believe they started making the bases thicker to help with vibration issues. 4 or 5 years ago i changed a number of base kits that included machine base, springs and snubber.
