ahh-cool
kitchenaide dishwaser kuds03ftwhs start/resume
11 posts in this topic
you guys were so wounderful and quick last time, let's see if we can do this again.
When I press the start button, the start, normal wash, and the heated dry lights illuminate. when I close the door the start/resume light starts flashing slowly.
Thanks again,
Stefan
Open door and press start again.  If leds are blinking control is paused.
how do I un-pause it
I did that a few times but it keeps doing the same thing
Sensei Chat in FL offers the following:
Is it "Blinking Slowly" or "Flashing Rapidly?"
PROBLEM: Won’t Run and LED for Start/Resume Key is Blinking Slowly
Door switch not making contact:
1. Faulty or sloppy door latch assembly (which can be aggravated by high door closure force).
2. Faulty door switch (high resistance).
3. Faulty control does not detect door closed.
PROBLEM: Won’t Run and LED Above Key(s) is Flashing Rapidly
Short circuit(s) in keypad or in control’s input lines that read the keys (ribbon).
Read more: http://appliantology.org/topic/33994-kitchenaid-dishwasher-model-kuds03ftss-start-button-blinks/#ixzz2Tn62kI9L
Follow us: fixitnowsamurai on Facebook
Thank you, it's blinking slow, I had a feeling it was the switch just didn't want to take the door apart again. I will bypass it and see if it fixes it
again thank you
Also check that the control lock hasn't inadvertently been engaged. Try unlocking it by holding the lock key ~3 seconds. I have found that the unit will sometimes lock without the LED illuminating....
Thank you all so much. I found the one of the wires to the door switch disconnected.
stefan
Ahh-C00l A/C
Good job, Stefan!  And thanks for posting what you found.   :thumbsup:
Chat in FL slam dunks and scores again after an alley oop assist by Durham! Go Team!  gimme an "A"  gimmie a "P" gimmie a "P"  gimmie an "L"......ok ..so i get carried away.
