reeferman
Bosch Dishwasher SHU9915UC-U11
7 posts in this topic
I've been reading a lot of posts on the Bosch dishwasher before posting this. This machine seems to be stuck in drain mode.
I have replaced the drain pump, which was really noisy.
Is the likely culprit a stuck water fill sensor or a stuck flood switch? If so, where are these parts located, and, to service them, will the dishwasher have to be pulled out of the cabinet?
Thank you.
Please describe "stuck in drain mode".
It could possibly be a bad door switch.
Howdy, Reeferman!  Usually on these Bosch dishwashers, when the drain pump runs all the time, there's been a leak.  Check the base pan carefully for any water in there.  If there is, you'll probably need the wash impeller and seal kit:  http://www.repairclinic.com/PartDetail/Impeller-and-Seal-Kit/167085/935404
Impeller-and-Seal-Kit-167085-00858579.jp
Not a bad job.  If you click link above, there's a video on that page that shows how to install it.
Been away for a bit. When the door is closed the unit just sits there in drain mode. It does not fill or wash; it just sits there trying to drain. I guess it was left one day and the drain motor wore out, which is what I replaced. But when I finished replacing the pump and closed the door, the unit just sat there in drain mode and no amount of pressing buttons could stop it.
In answer to the water leak in base pan, I was not able to detect any water or evidence of water in the base pan. It appears to have been dry for quite some time. I have read many related posts to this brand and similar type of d/w and will take a close look at all of the connections behind the control panel. I have to go back to this today...thank you!!!
Brother reefer, could be a stuck safety float.  Provided there's no leak detected in the base, particularly under the circulating motor or at the drain hose.  Remove the bottom access panel.  With the unit running, take a long screwdriver and manipulate the red float plunger located behind the inlet valve.  (Be mindful not to contact the wire connectors at the valve).  Push the actuator down and see if it disengages the drain pump.  If it does, the unit should call for water and begin the wash cycle.  Watch for leaking from the circulating motor, which is the most common source for leaks on the Bosch.
Konichi-wa! (my apologies for spelling - no neighbors from Japan to learn from)
It was a stuck float. I'm unaware of how it got that way so I'll keep an eye on this. Once again I feel the awesome force of this website, from the three of you...thank you.
Domo for the followup!
