  • Announcements
TimBeckler
LG LDF6920ST dishwasher heater turns on when door is closed
17 posts in this topic
Hi, My LG LDF6920ST dishwasher just started an interesting behavior.
I opened it the next day after it finished it's wash cycle and the thing was very warm and full of steam!
I then discovered that even with the power button off, the heating element is getting hot when the door is simply closed.
If you open the door you can hear a sizzling sound that gradually stops when you open the door. Close the door for 10 seconds and open it again you can hear the sizzling sound again.
I have taken the door apart and reseated all connectors but it did not help.
Any ideas as to what part failure might cause that? I'd appreciate any input.
Thanks!
Tim
Most likely a stuck heater switch in the door latch assembly:  http://www.repairclinic.com/PartDetail/Door-Latch/4027ED3002A/1267482?modelNumber=LDF6920ST
Can use your ohm meter to see if the NO and NC contacts switch when the latch is actuated.  Here's your wiring diagram:
Check the thermistor resistance and replace if out of spec:  http://www.repairclinic.com/PartDetail/Sensor/6501ED2002H/2246857?modelNumber=LDF6920ST
If both of those check good, then the main control board is keeping voltage on the element and it should be replaced:  http://www.repairclinic.com/PartDetail/Main-Control-Board/6871DD1006Q/1522430?modelNumber=LDF6920ST
Main-Control-Board-6871DD1006Q-00727530.
Thanks much! Unfortunately, it's looking like the PCB is bad. Appreciate your help. Thanks again
Please let us know how it turns out!
Well, I'm afraid a new PCB did not help. The micro-switches in the door open and close normally per my ohm meter and the thermistor is at 14K ohms when I measure across pins 4 and 5 of the unplugged RD6 connector. That seems to be in range. Dang, any other things I should check?
The Heater may have a partial short to it's case / ground.
Disconnect the Heater and OHM check for a short to it's case / (damaged?) sheath.
Any part purchased from RepairClinic can be returned for a refund (less shipping)
including installed electrical parts
Also check heater wire harness for short to ground (chassis).  Check wire harness for damage at bottom/right corner of door liner.  Be sure main power connections in box located behind bottom access panel haven't shorted.
Thanks for all the feedback.
OK, I've unplugged RD3 and BL4.
RD3 just has two wires, one to the heater, the other to the far side of the door switch
Resistance across pins 1 and 3 of RD3 is infinite with the door latch open, as I would expect
Goes to 4-6 Megohms (kinda jumps around) with the door latch closed.
That is the same resistance from RD3 -pin3 to ground, and from RD3-pin 3 to BL4-pin 1
The diagram shows that heater resistance should be 11.8 ohms but I'm not so sure that's correct  (unless I'm missing something...)
The wiring harness is well protected in a heavy plastic sleeve where it goes underneath. I can't see anything wrong there.
Beside this odd problem, the dishwasher works fine otherwise. :kopkrab:
OK, I disconnected all plugs from the pcb and measured from RD3-pin 3 to the outside of the heater sheath.
Got about 2 Megohms so I don't think it's shorted.
OK
It's either a bad Controller, or a short in the wiring.
With everything connected, but power removed from the DishWasher Power Cord,
(and Door closed)
measure from each of the connections on the Heater to:
chassis / ground
Neutral
Line
Thank you.
RD3-pin3 to:
Gnd:3.3 Megohm
Line: 120k ohm
Neutral: 6 Megohm
Other side of heater at the switch connector in the latch:
Gnd: 300k ohm
Neutral: 3 Megohm
Line: appears to be direct short,
RD3- pin1 is shorted to line on the pcb (with RD3 unplugged)
if I unplug connector WH3, the short at RD3-P1 goes away
With WH3 unplugged, the white wire at pin 1 is shorted to line.
that may be normal, but in order for the Heater to be ON when the Door is closed,
RD3-3 would need to be at Neutral somehow...
would seem to be a bad Controller ?
It sure seems unlikely that an old a new controller would have the exact same failure.
What if the float switch thinks the tub is full of water, when it's not? How would I test that?
shouldn't heat the water if the Power Switch is OFF
Well, finally got it fixed. The heating element had burned completely through.
Thanks for all the help. Anyone need a new 6871DD1006Q Controller? Only $50!
Good job! Thanks for posting whatcha found!
