nti
GE Refrig - Are all of them built as Profile Design?
7 posts in this topic
GE Refrig - Within the last 5-6 years, are all of them built on the Profile Model Design?  And where do we get additional info or repair specs other then GE?
Model # GSS20DBMBWW
This unit has the Control Board on rear of frig.   Is there an instrument avail to diagnose board other then Hammer, screw driver and wet finger tip ?
Thanks, Mike
Along with the tech sheet for your refrigerator which, by the way, is located in your refrigerator... unless it's been stolen by some slimeball, you'll find two instruments to be most expedient for your repair efforts:
1. A simple multimeter
2. Your brain... sans suds. :gulp:
Thank you, Exalted Grand Master of Appliantology.  The def heater is burned up and T-Stat is rattling.  Suggestions from Exalted Grand Master of Appliantology is requested.  ;) Thanks, Mike
Never seen or heard of a rattling t'stat. Don't see how they could-- no moving parts.
Fans rattle.
Double check that.
Replace the bad defrost heater.  Define " rattling t'stat"
Def T-Stat raddles if shaking.   Was wondering what caused the heater to burn up on two yr old refrigerator.   If the t-stat does not open to turn off heater until 140 degrees what exactly monitors and cycles the heater.  I am assuming that the heater does not actually operate at the higher temp of 140 degrees.   I am also assuming it's the thermister or a sensor in the freezer compartment....or is it controlled by something else?  These newer GE frig are beating me up.  Thanks for the feedback.  Mike
     You can order a defrost heater harness for a few dollars more.  It's a defrost heater, defrost T-stat (terminator) and all the wiring in one neat little package.
     I've seen that 140 degree figure twice recently in this forum.  The defrost t-stat opens at 50 or 60 degrees.  Where are you getting that number from?
     Why did it only last two years?  It's the quality of the product.  GE has been making garbage for over 10 years now.
      You'll need the service manual if you're gonna run calls on the newer GE refrigerators.
