bogreen
Maytag Refrigerator Model #MFI2067AES
8 posts in this topic
Hi,
This customer is complaining that every 2 weeks or so, the unit starts to warm up and the flap in the ice chute keeps opening and closing out of control.
They've turned the breaker off and everything has gone back to normal, but it happens again a couple of weeks later.
I feel like I've entered another of those times when I get all the weird calls.
Bruce
yep the ol' ghost in the ice chute door problem.....dead give away..mainboard failure discussed quite a bit in a complaint forum http://www.complaintsboard.com/complaints/maytag-french-door-refrigerator-c5247.html and what's so cool...on page 3 or 4 someone told the others of a great site that helped them fix their problem...Appliantology!..well in its earlier form as applanceguru.com...here is the thread that was referenced....http://applianceguru.com/view_topic.php?id=13035&forum_id=1&jump_to=75815
OK, the customer finally called and said they want the board changed.
I got it and arrived today.
Installed the new board and finished by programming the code.
I did all the steps, everything going fine. I entered the Code from the plate in the refrigerator
and then the final step was to hold the Freezer "down" key until the code started blinking.
It never started blinking, but instead "beeped".
Per the instructions, if it beeps, it means the code is not saved in the computer and won't run.
So, I did the steps again, and again, and again, and never could get the code saved. It would
beep everytime.
Damn this is frustrating.
So, I put the old board back and told the customer I'd order another one. No problem there.
Have you heard of this happening?? Or is there some step that I didn't do??
Bruce
Did you verify the programming code? If you put the original board in programming mode, it will give you the programming code also.
I didn't check the code that way, but on the Model # plate in the refrigerator the code 1311 was very visible.
I was nervous about putting the old board into programming in case it would'nt go back.
Then I'd have two boards and a customer with her refrigerator not working at all.
