Sign in to follow this
Followers 0
jkirksey1889
How to test Dryer Timer 8299771
7 posts in this topic
How can I test this timer?  Dryer not heating.  Element, thermistor, thermostats, power all good.  Down to the timer or dryness panel.
110.60992990
Edited by jkirksey1889
Bad start switch.  Problem fixed.  I jumped the gun a little.
Bad start switch
Then the Drum Motor wouldn't run...
You didn't mention that ... :whistling:
Won't heat without Motor running
The problem was that the dryer wouldn't heat.  The motor was running.  After fighting with it I found out that the dryer was also starting without having to push the start button.  The start button was staying closed.  Once opened the dryer started heating.
seems like you had more than one problem...
No-Heat issue will probably return
Kinda thinking that myself.  I could use a schematic for this model if you wouldn't mind sharing.  I, like you, feel like the problem will show back up.
Followers 0
