Derik
Double oven pleb30t8ccb
10 posts in this topic
Upper oven no bake or broil!!! Check across each side of element and get 120vac, check across both together and no voltage!!! Can't find no burnt wires!!! Any ideas where I lost my neutral
Bottom oven works fine on broil and bake!
No neutral loss...pull the upper oven relay board and see if you see a burned solder on the double line break...might be able to repair it, if so.
Which is upper oven relay brd
Oven Elements are 220v ... they don't use Neutral
try pushing the red reset button on # 119
Have you used Self-clean lately ?  :nono:
Not sure..are both ovens convection?
If not, the one with the extra relay.
Or you could check both.
Had already checked reset button on thermodisc and the sensor is closed(good)! No self cleaning for us
sounds like the DLB Relay on the Relay Board may be bad
http://www.repairclinic.com/PartDetail/Relay-Board/318022002/499739
make sure neither Element is partially shorted to chassis /ground..
may have caused Relay failure.
While either Element should be heating,
measure the voltage across the wires exiting the top of the DLB Relay (while connected)
0v = good
240v = bad
Thanks everyone!!! Relay brd with transformer had two seperate cold solder spots on back of control!!! Resoldered both and back in bizness!!! U guys r awsome and quick to reply!!!
Nice work :-)
