Coke Bear
Grinding noise in Kenmore dryer (11066812690) when drum is loaded.
5 posts in this topic
I need help fixing a grinding-type noise on my Kenmore Dryer (model 11066812690).
The grinding noise seems to be worse when the clothes are first put in there.
It has been happening for a while now.  It's to the point that it will only run for a few minutes before it shuts down.  It seems like it is dragging / grinding to a halt.
I removed the all wet clothes from the dryer.  Then I removed the front panel.  The drum rotates smoothly without weight.  The belt is about a year or two old.  It does NOT seem stretched or worn.
I turned the dryer on (sans clothes) and it ran quietly.  When I put wet towels back in the dryer and turned it on, it made the graiding noise again.
Thanks in advance!
Sounds like a pencil or something may be caught down in the blower wheel:  http://www.repairclinic.com/PartDetail/Blower-Wheel/694089/686172?modelNumber=110.66812690
There's a video at the link above that shows how to disassemble the dryer to access the blower wheel.
I'll check that, but I'm not sure why the noise ceases when nothing is in the drum.
Thanks for suggestion.
Sounds like a motor problem.  If the rear drum seal and front drum glide look ok, motor seems to protest with a load.  Could be an internal rotor problem causing the thermal cutout in the motor to shut down after a few minutes.
