Kokanee Ranger
Maytag mah2400aww
6 posts in this topic
As I am unable to post on other threads at this time I would like to say I am a Tech servicing downtown Vancouver . The Patina a 37 story hi rise at 1028 Barclay st. has over 250 mah2400aww. washers .A wonderful Maytag product made by Samsung . Before it was occupied I was called in on six “ LE codes” after it was opened I got anther six “LE codes” in every case I changed out the control board part number 34001379 and fixed the problem. Other then pulling coins and shite out of the drain pump , this is the only only part I have EVER changed out on this modal in over two years to fix this unit . The W/P part retails for $230.92 up here . The same part from Samsung retails for $142.90.
Another clue if you hit the Power button and you don't hear chimes change out the control board.
Welcome to Appliantology, Kokanee.  Grasshoppers can't reply to topics started by other people.  But we have a special membership explained on the Membership page for Brethren in The Craft, such as yourself: Master Appliantologist.  It's a complimentary upgrade for professional Appliantologists that gives full access to all the features of the site, access to tech-only forums, chat room, reply to other people's topics, and access to file downloads.  This is a free upgrade in the sense that there's no money involved, just information.  To download a service manual, you need to make two posts (any kind of posts count).  The idea is that you're supporting the site with your appliance repair knowledge and wisdom instead of monetarily.
You have been inducted into the inner circle of Master Appliantologists.
Kanpai!   :samurai:
Kokanee Ranger, What is the definition of 'LE' code for that model number????.......Six units with that code and they have never been used????.......then six units that have been in service, code 'LE'........Thanks for the tip on the control board.....ay..
LE= washer has tryed to fill but has not reached the proper water level.
On one other repair on a mah2400aww I diagnosed a bad motor, replacing the motor, was not a fix , changing the board was the fix.
At the Pinical with over 250 units and 12 bad boards a failure rate of 4.8%. Manufacures aim for 2% or less.
Concur with Brother Kokanee on the pumps for these Maysungs and the Samsung pumps what we used for truck stock.  Did have some where the board did not energize the pump with no fault code indicated.
