Sign in to follow this
Followers 0
philmang
Miele Tumbel Dryer
4 posts in this topic
I have a Miele T4222C Condensor Tumble Dryer. If I used the timed function it works ok.IfI use any of the automatic functions it starts and after about 30 |Seconds the heater comes on and it immediately stops with the alarm on and Anti Crease / Finish Light on. I have checked the Front NTC and it seems ok , couldit be the Residual Damp Sensor giving problems. Any help would be greatly appreciated. Thank you.
any one help here guys . strangely silent on any tips.
Do you have damp items in drum?  Sounds basic, but the entire drum is a sensor on these and will only run briefly if nothing is in the drum on auto sensing cycles.  Wet down a couple of towels and try it again.  If it works on time ok then I would presume sensing circuit is shutting it down. If you had items in it then check the sensor circuit
2 people like this
Check the sensing brushes riding to top of drum for proper alignment and contact.
1 person likes this
Followers 0
