Topy
Fisher Paykel E522BRFXDU2 Water dispenser not working.
8 posts in this topic
Hi,
I have a problem with my fridge, a E522B about 5years old. Product 22119-a, Model Number E522BRXFDU. Looks like a e522brxu2.
The water dispenser doesn't work.
I push the dispenser button and no water comes out and water tap crossed icon comes up on the display.
I have check the solenoid valve and it works.
It seems that the 12V current doesnt get to the valve for some reason.
Is there a service manual available for this model as I don't want to wreck it by opening the dipsnser panel to check the switch.
Thank You.
Edited by DurhamAppliance
added manufacturer's name to topic, corrected model no.
did it work previously ? or have you just connected water to it ?
if you have just connected waster to it then it will take a few minutes of holding the button in
to get the tank filled and water to come out
if the no tap symbol is working then the switch is working
other possibility is that the water line inside the fridge is frozen which did happen in some production
as they put the water line next the the refridgeration line
you can check this by using some whipper snipper/weed whacker cord up the water hose from the water valve end
Yes it used to work fine. It started to "play up". The tap icon used to come up and no water. Then after a few hours water would come out again.
Now it doesnt work at all.
I cleared the lines and air was passing through.
Solenoid is ok.
Ice maker works.
Thank you for your help.
Edited by Topy
maybe you have a crook water solenoid
quite unusual but possible
its going to be one of those things you will need to work out step by step when it stops working
I have tested the solenoid and it is ok. When appying 12v current it opens. Both solenoids (water and ice) are ok.
So far i know that when the dispenser button is pressed there is no current going to the water solenoid. Nothing accros the two tabs of the blue terminal.
I just need to locate where those wires go back to in the fridge.
Thanks for the help.
check the wiring at the top of the door at the hinge
the cover comes off pretty easy
betting you have a broken wire there
Spot on !!
Problem fixed now.
I was planning to pull the fridge appart this week end. no need now thanks to you.
Fixed in 5 minutes.
Thank you again for your help.
Good call, Brother J5!   :rocker:
