Bosch WFMC3200 works, quits. works again, quits again
37 replies to this topic
#21 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 July 2013 - 03:49 PM
http://appliantology...al-1st-edition/
#22 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
  • Flavorite Brew:yuenling
Posted 11 July 2013 - 04:17 PM
Thank you. Digital copy much handier than paper.....If I spill coffee all over the print out I can always print off another.
#23 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 17 July 2013 - 02:21 PM
Replaced the power harness to the motor control and the harness from control to the motor.  Now all I'm getting it a persistent E:20 when running P:03 and P:04. Now I am also not getting any agitation motion at all either, so should I be casting a jaundiced eye at the motor or motor control? Starting to seriously consider having major argument with spouse and buying a new washer....but would rather fix this one since I started on it.
#24 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 17 July 2013 - 03:58 PM
Forgot to add the E:20 does not seem to be incrementing the count has been at C:05 since this started.
#25 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 20 July 2013 - 05:25 PM
Ohmed out the motor. Results as follows....
7-8 3.3 ohms
6-8 3.3 ohms
6-7 3.3 ohms
4-5 283.0 ohms
4-5 with drum spun by hand readings all over the place
question is motor or control board
#26 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,954 posts
Posted 20 July 2013 - 05:28 PM
If 4-5 is the motor tach, then the motor seems good.  Replace the motor control board:  http://www.repaircli...Number=WFMC3200
#27 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 20 July 2013 - 05:33 PM
Assuming 4-5 is the motor tach the schematic isn't real plain on that shows lines going from 4 and 5 to a circle with a g in it.
#28 Samurai Appliance Repair Man
    Shōgun
  • 30,954 posts
Posted 20 July 2013 - 05:36 PM
"g" stands for the German word, "Geschwindigkeitsmesser" which IS a tachometer.
Replace the board.
#29 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 20 July 2013 - 05:41 PM
Thank You will replace the board and report back.
#30 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 21 July 2013 - 08:55 AM
OK.....Here's the report from the Motor Control surgery....Removed the diseased motor control and replaced with a new healthy control.  Washer performed an empty cycle for cleaning purposes perfectly.  Put in a medium sized load of laundry items, the washer once again performed perfectly.  Will type up my debriefing in anther post.
#31 Samurai Appliance Repair Man
    Shōgun
  • 30,954 posts
Posted 21 July 2013 - 02:01 PM
Wow!  Repairclinic shipped you the board on a Sunday?  Awesome!   :thumbsup:
#32 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 21 July 2013 - 06:25 PM
No I had ordered the board when I ordered the harnesses, just in case it was needed....Figured better to have on hand and have to RMA, than need and not have.
#33 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 21 July 2013 - 07:02 PM
Well a little more to the saga....After two flawless loads the son of a motherless goat has decided it wants to throw some more errors.  Just got an E:04 which from manual perusal and searching around implicates door latch problems, main control board or pump. Any quick dirty tricks to find the culprit?
#34 Samurai Appliance Repair Man
    Shōgun
  • 30,954 posts
Posted 22 July 2013 - 06:39 AM
Does the washer pump out properly (good discharge flow, inner basket drained)?
#35 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 22 July 2013 - 03:01 PM
Pump is not pumping water out.  Ran p:09 last night and the test started out flashing P:09 63 then P:09 88 while putting in water. the test in the manual says it should go to 177 which would be from heating level to door locked level. The test throws an E:13 and aborts before it reaches 177.  P:15 never moves from 88 to 177 also throws E:13, with no sound from pump.  I am in the process of rigging up a water removal device combining an empty 2 liter bottle and a Shop Vac so we are either going to have just a little water on the floor or a small flood in the laundry room.
#36 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 29 July 2013 - 06:51 PM
Finally had time to dismember  disassemble to check the pump.  Removed the cover and drained the rest of the water out. Removed the drain hose and performed the bugle test and the flow of air and some water was unobstructed. Removed sump hose and poured water through the tub and sump drained freely.  Now on to the pump exam.
Performed ohm test on pump. Pump reads 16 ohms rather than the 140 - 200 ohms in the specs.  Also checked the harness to the pump and it is getting approximately 46 volts but that could be my meter and leads. So where do we go from here?
#37 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 30 July 2013 - 09:40 AM
Some new information on this. Decided to redo my testing from last evening. Plugged my meter back into the pump harness, plugged the machine back in and lo and behold 115 volts at pump harness, with washer just plugged in no cycle or test selected.  So i decide lets energize the thing and start a spin cycle since that will start the pump first, voltage goes from 115 to 46. This seems to be backwards to me since the duty cycle for the pump is 15 on/45 off.
#38 DocSardonic
DocSardonic
    Ikkō-ikki
  • 25 posts
Posted 06 August 2013 - 08:15 AM
Can't spend any more time on this. Washer is being parted out and replaced.
