MayTag Bravo Quiet Series 300
5 replies to this topic
#1 sugersnps
sugersnps
  • 2 posts
Posted 30 May 2013 - 11:54 PM
My Dryer suddenly stopped heating up ,I noticed that my Status Lights aren't coming on now. What could be wrong?
#2 suampman
suampman
    Kohai
  • Chief+ Appliantologist
  • 307 posts
  • Flavorite Brew:redbridge
Posted 31 May 2013 - 08:46 AM
You will need to post your model number. It should be inside the door.
#3 PDuff
PDuff
  • 2,158 posts
Posted 31 May 2013 - 10:14 AM
Also check and reset your circuit breaker if necessary.
#4 MicaBay
MicaBay
    Master Roaster
  • 1,115 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 31 May 2013 - 04:37 PM
Does it heat up on timed dry, automatic dry or neither?
#5 sugersnps
sugersnps
  • 2 posts
Posted 01 June 2013 - 01:21 AM
Model number is MEDB400VQ0
Neither
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 June 2013 - 03:56 AM
check and reset your House Circuit Breakers
Check for 120v and 220v at the Dryer Cord Terminal Strip
Check resistance of Heater Element
check Thermal Cut-out device on the Heater Element assembly
also check the Belt on the Blower Housing
http://www.repaircli...R=154&N=1180102
High-Limit-Thermostat-8557403-01023978.j
http://www.repaircli...R=154&N=1180054
Heating-Element-Assembly-8544771-0118539
http://www.repaircli...R=154&N=1180047
