Sonic
Panasonic M/W NNSD297S dead short
5 posts in this topic
All the door switches test good. I even disconnected the short switch to make sure it wasn't an issue and I still popped the fuse. Magnetron not shorted to ground. I pulled the inverter and saw no damage. I Ohmed the CN703 with the magnetron leads disconnected and read continuity/ 0 ohms. This would shunt the magnetron and blow the fuse..yes?
Did you test the magnetron from one of its terminals to ground?
Also, at what point during heating is the line fuse blowing?
I tested the magnetron from the leads going to the inverter board to ground.  The fuse blows right after I press start to cook. .
