Kitchenaid KUDP02CRB51
No washee
40 replies to this topic
#1 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
  • Flavorite Brew:corona
Posted 31 May 2013 - 09:07 AM
Hello all,newbee here.
My dishwasher is confused. intermittantly works.
For the past 6 mos., it would only turn on w/ Normal wash & the 3 drying lights-then start button.
Now,those lights work,but not starting/running.
Any help/advice?
> Control Board?
Thanks,Jeff.
#2 PDuff
PDuff
  • 2,013 posts
Posted 31 May 2013 - 10:30 AM
Is the start led flashing?  If it is, is it flashing slowly or rapidly?  Try pressing cancel.  De-energize unit for 5 minutes then re-energize and attempt to enter diagnostic mode to check component operation.  Press heated dry-normal-heated dry-normal within a 6 second time frame and close door.  Should advance through a quick test cycle.
#3 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 31 May 2013 - 04:19 PM
Hi.
The 'Normal' wash button does not illuminate now. Only - the drying  buttons light up.?
Can I assume, the diagnostic sequence you spoke of consists of the "heated dry-then normal >(wash button),heated dry,normal wash?
Jeff
#4 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 31 May 2013 - 04:40 PM
OK, tried to enter Diagnostic mode. Nothing.
I had/have NO  'start'  LED: flashing or steady.
As to D mode, should I have door open prior to enter D mode?
Cancel button does nothing-won't turn off the 3 lights that do illuminate> 'Hi-Temp Scrub,-Sani-Rinse,-Heat Dry.
Pushing each light will turn them on/off.
Help me Obi-Wan.
Jeff.
#5 PDuff
PDuff
  • 2,013 posts
Posted 31 May 2013 - 06:05 PM
Affirmative on sequence.  Doesn't matter if door is open or closed when first activating diagnostic mode but door needs to be closed to engage mode.  If that fails, try Sani Rinse-Heat Dry-Sani Rinse-Heat Dry and close door.  The previous keydance came from the tech sheet for your model but the second keydance works on many models.  If successful all leds should light and with door closed should proceed through 5 minute test cycle where it test runs all components.  If can't access diagnostic could be bad touch control (console).  If access is successful, all leds light and nothing else happens with door closed, might be a bad door latch assy.
#6 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 31 May 2013 - 06:43 PM
OK.
The second method seems to work:
All LEDs lit,then proceeded to cycle thru 'some'functions. Normal wash,Rinse only,Drain.and Dry light....
Then shut down.
NO flashing lights,etc. to tell me any codes?
What's next,wise one?
Jeff
* shouldn't your beer be "DUFF"
#7 Budget Appliance Repair
  • 4,928 posts
Posted 01 June 2013 - 07:15 AM
Replace the touchpad/console assembly and all will be fixed.
All these membrane touchpads have problems and fail in all brands, some more than others.
Everything you describe points to bad touchpad.
William Burk (Willie)
Eureka, CA 95501
#8 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 01 June 2013 - 08:21 AM
Hi Willie,
While running Diagnostic, I pressed Normal wash, and machine ran thru cycle.
Still suspect Touchpad panel?
Thanks,Jeff.
    Shōgun
  • Master Samurai Tech
  • 30,042 posts
Posted 01 June 2013 - 10:22 AM
Yes.
Incomplete model number so don't know which color you have:
Black:  http://www.repaircli...8572205/1180633
White:  http://www.repaircli...8572206/1180634
#10 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 01 June 2013 - 12:17 PM
Very well, oh wise one(s).
Mine is ebony.
I shall order forthwith and think good thoughts about that damn bridge,er panel.
Have a good one,
Jeff.
    Shōgun
  • 30,042 posts
Posted 01 June 2013 - 12:28 PM
Keep us posted!
#12 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 01 June 2013 - 12:41 PM
Dillwue,Willdue,Waldo
OK.
#13 Budget Appliance Repair
  • 4,928 posts
Posted 02 June 2013 - 07:05 AM
Generally diagnostics don't use the start key to run the diagnostics.
If you can get the touchpad to respond to the diagnostic starting procedure and it goes thru the diagnostics that proves your main control board is OK.
Another test on a lot of the newer Whirlpools/KitchenAids is to turn power off to unit disconnect key pad from controller reapply power and shut the door.  If the control board is good it should go into a 2 minute drain cycle and stop.  If it does that it also proves the controller is OK and didn't see the touchpad, so by default your touchpad is bad if it won't work.
Eureka, CA 95501
#14 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 02 June 2013 - 10:41 AM
Sensei Willie,
I have ordered the pad/console assy.
I shall pray for husbands everywhere that it is the needed part.
I'll post results after completion of my appointed task.
Humbly, Gassyhopper
#15 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 June 2013 - 11:35 AM
any part ordered from RepairClinic can be returned for a refund (less shipping)
including installed electrical parts
#16 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 02 June 2013 - 07:20 PM
'Twas ordered from same,oh Funky one.
Must be close to me in age,for I see a test pattern, and can almost here the sign off tone...
#17 RegUS_PatOff
  • 33,588 posts
Posted 02 June 2013 - 07:37 PM
... I see a test pattern, and can almost here the sign off tone...
"I can name that tune in . . .  one note."
#18 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 03 June 2013 - 01:53 PM
Funky One, I'm sure you can,but no one of importance cares anymore. Those of 'our' age,probably couldn't even hear it!
I remember a test pattern that had an Indian Chief picture in the middle. Pittsburgh,PA ,late '50s-early '60s.
Of course, The Star Spangled Banner played before the monotone.
Jeff.
#19 whilst01
whilst01
    Ikkō-ikki
  • 25 posts
Posted 03 June 2013 - 02:03 PM
And 'not' the old scoot one.
"Chow"  the poodle bites..
#20 RegUS_PatOff
  • 33,588 posts
Posted 03 June 2013 - 02:09 PM
trivia:
Do you know the (3) musical notes of the NBC Logo ?
hint: NBC was originally (and now again) owned by the GE Corporation:whistling:
