biscuit
Maytag mf12266aeu not cooling
11 posts in this topic
I have replaced the HV board and reprogrammed unit appears to be running but not cooling any help
... appears to be running but not cooling any help
Compressor is running ?
Yes you can hear it start
may need to see the frost pattern of the Freezer Evaporator Coils
after the Compressor has been running an hour or two ..
OK let me ck
OK compressor seems to be running nothing is frosted I think the thermal is kicking out the compressor is getting hot unit is about 5yrs old and has been in storage for a yr could it be low on freon
Why was the high voltage replaced?  What were your original symptoms?  Also check condenser fan operation.
the compressor has a slight vibration to the touch
The unit wouldn't do anything on the front panel so I changed the HV board
If compressor is running and no frost whatsoever on evaporator then it sounds like a sealed system problem.  Unit was in storage for a year.  Was it transported on it's back or side before restarting?  Sometimes oil in the hermetically sealed compressor can transfer into the refrigerant lines and gum up the filter/drier causing a restriction.
