Kenmore T/L Washer 110.28002011
No motor action
6 replies to this topic
#1 elmonducky
elmonducky
    Sōhei
  • 230 posts
  • Flavorite Brew:Cabernet Sauvignon
Posted 01 June 2013 - 06:21 PM
Washer fills, goes through complete cycle with no wash or spin action.  No hum, so sound of any kind.  At end of cyle it drains, no spin.  counts down to zero then shuts off.  Motor and Main board have been replaced, no change. Recalibration has been performed according to instructions, no change.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 June 2013 - 07:09 PM
any error codes ?
Tech Sheet - W10338674
http://appliantology...er-tech-sheets/
#3 elmonducky
elmonducky
    Sōhei
  • 230 posts
Posted 02 June 2013 - 10:24 PM
Previous tech claimed f7 and e6 codes but could not find any when i ran diagnostics.  THought I might have a bad connection but all checked good.  The only thing I could confirm is that I had no voltage from pins 1&2 on I believe it was J16 conn when I put into spin cycle.  Tech sheet says if no voltage replace board but I already did that.
#4 RegUS_PatOff
  • 33,588 posts
Posted 02 June 2013 - 11:37 PM
... Previous tech claimed f7 and e6
... THought I might have a bad connection but all checked good.
... The only thing I could confirm is that I had no voltage from pins 1&2 on ... J16 in spin cycle.
... Tech sheet says if no voltage replace board but I already did that.
F7 E6 MOTOR FAULT
Indicates an open clockwise or counterclockwise circuit of the motor.
• See TEST #3b: Drive System–Motor, page 14
middle of page 14, right column:
TEST #3b: Drive System – Motor
This test checks the motor, motor windings, wiring, and start capacitor.
NOTE: Refer to Figure 5, “PSC Motor Strip Circuit” on page 15 for tests and measurements.
#5 elmonducky
elmonducky
    Sōhei
  • 230 posts
Posted 03 June 2013 - 08:36 AM
Motor has been replaced as stated above.
#6 RegUS_PatOff
  • 33,588 posts
Posted 03 June 2013 - 09:19 AM
If it's not the Controller and not the Motor
(assuming you got good replacement parts)
these tests also test the wiring
#7 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 799 posts
  • Flavorite Brew:yeunling
Posted 03 June 2013 - 06:00 PM
broken wires are a very common problem on these machines
