  • Announcements
BK1017
LG Fridge LFC22740ST Not Cooling
8 posts in this topic
First of all, thank you for your patience. This forum/site has proved to be very useful in my endeavor of getting my fridge fixed, and I hope it will help me a bit more.
The problem: My LG fridge stopped cooling. It has been going on for some time (months?) but my solution was always to unplug the unit, then plug it back in and viola, cold air. The pull out freezer has worked great through all of it though. Finally this weekend the solution didn't work, so I called out a tech today. He said pretty quickly that the PCB board needed to be replaced, but did not pull out his multimeter or infrared thermometer. Just kind of felt around for air flow, checked the door switches, and turned the unit off/on. He did mention an excess of frost built up in the freezer.
However, the unit continued to work normally again as I left the house, so I'm skeptical as to whether the board actually needs to be replaced. I read the 'warm fridge fire drill' and also the FAQ's, so I'm thinking that I need to clean the bottom of the unit and possibly defrost the unit. Thoughts?
I went ahead and ordered the PCB just in case. The installation seems straight forward, but can I do this myself? If so, any tips/tricks or advice? The technician warned against this, stating that he may need to program it. I'm not totally convinced that's the case though.
Any advice on how next to proceed would be grateful. Thanks in advance.
Brian-San
I am having a similar issue on a lg made kenmore.. ... one thing to check is your pcb cover. If it is plastic, there is a possibility of interference with the board. see
http://appliantology.org/topic/42094-kenmore-lg-made-fridge-79565009401-intermittent-problem/
The cover was on back order and I will know if it fixes my problem soon. It costs about $80 so I ordered it from repairclinic just in case it doesn't stop the probem
Have there been any fault codes displayed, er ff or anything else?
The cover was on back order and I will know if it fixes the problem soon
Thanks, but mine has a metal cover.
I have not seen any fault codes.
BK
Then I can't think of anything other than the board. Can you tell if this happens after defrost... and do the lights on the interface dim out when it's off?
The main PCB is failing to start the compressor.  This is verified by the fact that you have to cycle power to get the compressor to run.  When you cycle power, it initiates a main PCB self-test, which includes starting the compressor.  Beyond the self test, it's not starting the compressor.   Go ahead and replace the main PCB:  http://www.repairclinic.com/PartDetail/Main-Control-Board/EBR36222901/1369149?modelNumber=LFC22740ST
Main-Control-Board-EBR36222901-00787886.
Got it. Thanks. Replacing the board seems like a basic plug and play job. Any concerns when doing this?
Since the tech's visit, the fridge has continued to operate like normal. He must have a magic touch.
BK
Static electricity is the big killer of these boards.  Handle only by edges, touch a grounded metal surface before and during replacement, wearing a grounding strap is preferable.
If it ain't broke, why fix it?
