Learn how to troubleshoot like a Master Samurai Tech...
fjrdc
GE Profile Harmony gas dryer intermittenet heat
13 posts in this topic
Hi, I have a GE Harmony Dryer (DPGT750GC0WW) that starts normally ,the burner will  start after 30 seconds, runs for 30-45 seconds and shut off.
The diagnostic screen shows no errors , took apart dryer tested all sensors all are within  the paramaters in the TSM.
Went to the factory test screen everything seems to be correct , I am at a loss any help  would be appreciated !!
how's the Vent system ?
Disconnect the vent from the back of the dryer ans try it again. Let us know.
Disconnected dryer vent ( I didn't mention that I cleaned out the whole vent system, 2 elbows & a 4ft run of pipe) ran dryer , in factory test mode blower ramped up to 2,000 -2,100 rpm after 25-35 seconds after 45 seconds flame sensor came on and within 10 seconds you could hear the burner start and the info screen  shows "heating" --ok .
All points say "OK"
... info screen  shows "heating" --ok .
All points say "OK"
"Life's good"
GE Harmony . . . made by LG    :whistling:
After heating for about 2 1/2- 3 min heater went off, dryer still running, flame sensor says "ON"  inlet THD peaked at 438 F and inlet THD 110
I know! , Six years ago they hadn't developed their reputation by then
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
 $ 3.99 sometimes on sale for $ 2.99
All points say "OK"
So... it heated normally with the vent hose disconnected?
It heated for approxamtely 3 min. and heat kicked off  ,dryer continuied to run no heat, after 8-10 min heat kicked back on ...
has this Dryer worked OK up till now at this location ?
Dryer is now fully re-assembled ?
Yes, 6 years , fully assembled except for ventpipe.
If that blower motor runs intermittently, this will cause the flame to stop.  Is the blower motor running the entire time?
Also, check to see if the liner valve and both the other DC valves on the gas valve assembly are continuously getting 12vdc.  Can check this at CN16 on the main PCB.  Refer to the mini-manual/tech sheet for details.
