LG Refrigerator Leaking from Reservoir
5 replies to this topic
#1 global
global
  • Chief Appliantologist
  • 5 posts
Posted 05 June 2013 - 09:30 AM
Hi.  I know this is an old thread, but looks like same issue I am having.  The fridge is model # LRFC21760ST.  The molded reservoir is leaking and I received the tubing style as a replacement.  It does not fit.  I saw the service bulletin that was attached to the thread in the link above.  Not the same model number, but I assume it applies.  Can someone confirm, is there an updated bulletin?  Also, I assume there are two valves controlling water going to the dispenser that's why I can remove the valve in the door?
Deepak
Also, the replacement part I received is part number 4838JA2002B.
    Shōgun
  • Master Samurai Tech
  • 30,621 posts
Posted 06 June 2013 - 06:49 AM
Post split off from old topic into a new topic.
Can you re-check that model number-- sure it's not LRFC21755ST?
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 5,781 posts
Posted 06 June 2013 - 08:00 AM
or maybe LfC21760ST?
www.DurhamApplianceThrift.com
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 06 June 2013 - 08:07 AM
or maybe LRFC21760ST
http://www.lg.com/ca.../lg-LRFC21760ST
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 5,781 posts
Posted 06 June 2013 - 10:11 AM
Canadian model?
#6 global
global
  • 5 posts
Posted 08 June 2013 - 07:53 AM
It is a LRFC21760ST.  It's a good part number, user manual is here: http://www.ps2netdri...lg.lrfc21760st/
It is a french door, bottom freezer model.  It is in Canada, so maybe a Canada only model.
I'm thinking the bulletin CREF20060276 for LRFD21855ST would apply, but want some formal document in case of any issues.  I'd hate to remove the secondary water valve and have a leak down the road with no documents from LG.
