  • Announcements
Sign in to follow this
Followers 0
fixyourboard
GE Wall Oven: Display says "BAKE" but relays won't engage.
2 posts in this topic
From our tech support conversation:
  Tech Support: Is the door closed or open?
  Tech: Closed.
  .... long conversation with measurements etc ...
  Tech Support: I'd like to verify the functionality of the plunger switch on the door. Can you locate it?
  Tech: Yes, that's what I'm holding in to "close the door".
  .... Ka-Ching! ... Nooo!!!
  Tech Support: Please physically close the door and try again.
  Tech: The oven is heating!
TIME SAVING TIP ABOUT GE WALL OVEN:
If the control board thinks the door is open it prevents the heating element relays from engaging.
This is completely determined by the state of the 2 micro-switches in the LATCH MECHANISM.
(To cook switch #2 (top) MUST BE CLOSED, switch #1 (bottom) MUST BE OPEN)
The oven controller DOES NOT SENSE the PLUNGER switch!
Remember this to save wild geese. :woot:
Some of the older KitchenAid/Whirlpool built in wall oven must also have the door closed before they will heat.
Followers 0
