r&htelevision
Kenmore Mod.36275211101 No gas to oven
15 posts in this topic
Checked ignitorit was pulling 3.4a so replaced oven safty valve. Still no gas the gas line comes right from the regulator. Top burrners working fine. Is it possiable to get gas to burrners and not to oven safty valve. HERB
Moved to the Kitchen forum.
Maybe your current measurement was inaccurate and the ignitor really is bad?
Maybe the little valve on the regulator got knocked into the off position...
Thanks for resopnding. I cheched the ignitor twice checked ok.If the the regulator was switshed off would the top burners still work. HERB
Are all the holes open and clear on your oven burner tube especially in the pilot area adjacent to the ignitor?
If the regulator has the little lever near the gas tube that feeds the oven, then if it is turned off there will be no gas going to the oven at all and the surface burners will still work.
Any range that has a regulator with a little on/off lever - that lever only shuts off the gas to the oven not the surface burners.
If one of the wires to the Ignitors is shorted to chassis / ground,
you'll get those symptoms.
The Ignitor should read about 1 OHM
and about 3.3v AC
I believe you meant to say the gas safety valve should read about 1 OHM, (Not the ignitor)
The ignitor will have somewhere between 100-150 ohms if I recall correctly.
sorry, I'm not at home with with my desk-top computer,
I'm in a motel room this week-end with my 10" in hand ..
Sounds like an Aerosmith song...
sorry, I'm not at homw with with my desk-top computer,
You really should consider an upgrade.
I hope you're talking about Reg's tablet, Brother jumptrout.
Call it what you will.
Found lever on regulator missing. put another lever on working ok now.thank for everyones help. HERB
Found an  advertisement in the back of my A.A.P.R. magazine, for a larger upgrade, use a vacuum pump...... :thumbsup: ..............
