  • Announcements
    • Son of Samurai
      Contact the Samurai   01/01/2016
      <a data-cke-saved-href="https://mastersamuraitech.wufoo.com/forms/msvo81y1r0homk/" href="https://mastersamuraitech.wufoo.com/forms/msvo81y1r0homk/" rel="external">Fill out my Wufoo form!</a>
elmonducky
Frigidaire D/W EIDW6105GB1
6 posts in this topic
Not familiar with this model and did not have a schematic or fault code to determine the cause.  All likes blinking on and of continuously.  No response from touch control.  Unplugging did not clear.  No functions what so ever.  Suggestions??
Only one thing it can be in this one:
Part number: AP4357695
Thanks!
Remove bottom access panel and check main control for any lit leds.  Lit led is specific to affected component.  Access Component/Relay/Triac test as follows:
From power up press Sanitize and Delay Start
"Et" should be displayed (engineering test)
Press Rinse Only
"rt" should be displayed indicating component test mode.  Press the following buttons to toggle on/off each component:
Auto Sense-washer motor
Heavy-water valve
Normal-drain motor
Quick-drain valve
Rinse Only-Clean light led
Hi Temp-all leds on control housing
Sanitize-fan state
Air Dry-dispenser
When checking heater, always fill tub with water.
1 person likes this
Thanks I will copy this for future use, unfortunately there is absolutely no response from any of the touch keys to even run a diagnostics. Appreciate the breakdown.
All leds blinking indicates to the customer a fault with the control or wiring.  Be sure to de-energize for at least 5 minutes to reset control.
