The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
procreator
Kenmore gas dryer motor makes squealing noise
14 posts in this topic
I have a Kenmore gas dryer that makes an occasional high-pitched squealing noise. I think it might be a bearing.
Can this be repaired, or am I looking at a new motor?
Thanks!
Model # please.
Sorry.
Model 110 72712101
Edited by procreator
Do the maintenance kit that Thirsty posted before the motor. Even if you end up changing the motor, having new a new belt and all rollers is a good thing.
Not a good idea to oil the idler and drum rollers because the oil will collect lint and hair and actually cause premature failure of these parts. If they're worn and making noise, just replace them. They come pre-lubed with oil infused into the metal (supposedly).
I should explain that I completely removed the drum and belt and ran the dryer in air only mode. I determined that the sound was coming from the motor. The only moving part was the motor and the blower attached to it. Even without a load it would squeal at times.
It appears the only resolution is a new motor. Do you agree?
And you did a FOD walk-down in the blower area?
Good call Samurai!  I just pulled a pencil out of one today that was making a helluva noise........
I determined that it was the motor that was squealing. Nothing in the lint housing or around the blower.
Grand master is right.You should never oil rollers or pulley 38 years at doing this.
A-4-Roger-D on that, Big Buck Budrow!   :dude:
